94 camero v6 won't start.
Old 01-22-2017, 12:33 PM
Oldman's Avatar
Default 94 camero v6 won't start.
I have a 94 camero. I have bypassed the vats system, changed the fuel pump, new fuel filter, new plugs and wires , checked all fuses, good battery, it will crank but will not start. Running out of ideas any help wou ld be much appreciated.
Old 01-22-2017, 09:49 PM
is it getting spark? have you tried to squirt some strarting fluid or shot of gas in the throttle body and try to start to see if its a fuel problem
Old 01-23-2017, 08:50 AM
Everett#2390's Avatar
If above test shows getting spark and still does not start,
remove spark plugs and air them out.
They probably are soaked with fuel - no spark - grounded out plugs.
Old 01-23-2017, 03:33 PM
Oldman's Avatar
Have not tried that yet. I will as soon as it quits raining. Thanks for the info. I will let you know.
Old 01-23-2017, 05:46 PM
Oldman's Avatar
Pulled the #1 plug and it is dead, burnt and soaked in fuel. New plugs tomorrow.
Old 01-24-2017, 03:42 PM
94camarostl's Avatar
Default 94 camaro over heating when idle
Hey i got a 94 camaro 3.4 over heat when idle need help had a no start problem i changed battery .alt starter twice n all wires now im over heating n idle. Did thw water pump cause i had a leek
Old 01-25-2017, 06:00 PM
Oldman's Avatar
Well l changed the plugs and still no start. I did find that the wires that enter the plug that goes to the lower side of the icm were deteriated and the bare wires are touching. I also found the ground wire that hooked to the left side of the body/frame had come unbolted the engine. Have to fix this and see what happens.
Old 01-25-2017, 09:33 PM
still no spark?
Old 01-27-2017, 05:23 PM
Oldman's Avatar
Ok so the car won't even turn over. Fuel pump primes dash lights come on, not even a click from the solinoid. I can bypass the relay that is back behind the glove box and it will turn over but has no spark. Getting tired of this thing. What else is there check?
Old 01-27-2017, 08:11 PM
Oldman's Avatar
I got it figured out. Gut the car, put my 406 , 350 turbo trans in with a 9" Ford rear end and do it old school. This computer crap is for someone besides me.
Quick Reply: 94 camero v6 won't start.
