305 Tpi, not running to its full
Old 09-15-2010, 01:48 PM
jamguitarist91's Avatar
Default 305 Tpi, not running to its full
I have a 505 TPI in an 88 Iroc, the car likes to chug, run at half power, randomly die, and overheat easily.
Things I'm doing are:
New heated 02 sensor for the longtube headers
Full tune up
Also my car is a 1988, but for some reason it has a MASS air flow sensor AND a MAP sensor installed?? Yea...
Old 09-16-2010, 07:52 PM
microkid's Avatar
March 2011 ROTM
Technical User
sounds like theres a lot possibly wrong. we need more details. does it smoke, use oil, use coolant? what else is done to it. according to your other thread you wrecked it
Old 09-21-2010, 07:47 PM
It burns no oil, it ran like this before the wreck, it doesn't tick, it runs great till it warms up usually. does not use coolant.
Old 09-21-2010, 07:51 PM
microkid's Avatar
March 2011 ROTM
Technical User
i would start with the timing and go from there. there could be some sensor issues, a broken or inop coolant temp sensor could cause a few issues by telling the ecm the engine temp is -40. does it run rich, normal, or lean? there could be other issues as well, but lets start off with the simple
Old 09-21-2010, 10:33 PM
a 505 hugh? thats a big tpi
Old 09-24-2010, 08:54 AM
warbeckn's Avatar
Check the throttle position senser. I had mass airflow problems for a long time.
My senser was set open too far. I have an 86 but I think 88 has the same tpi.
Old 09-27-2010, 06:20 PM
black89rs's Avatar
are maf sensors supposed to glow??
Old 09-27-2010, 07:39 PM
microkid's Avatar
March 2011 ROTM
Technical User
during the clean off cycle after shutting off the key, that is normal. during operation, im not sure
TXMEL13
06-08-2011 12:01 PM
orlando_trudeau@yahoo.com
06-16-2009 12:35 PM
bdunegan
05-03-2008 09:08 AM
SickSickSick
General Racing/Tech
15
07-07-2006 10:56 PM
Quick Reply: 305 Tpi, not running to its full
