1986 z28 not starting
Old 10-27-2014, 02:02 PM
polinder_88's Avatar
Default 1986 z28 not starting
I have a 1986 z28 5.0 V8 that isn't starting.
I have poured gas into the carb. and it fires and runs rough for a few seconds until the gas is gone.
Fuel Pump?
Old 10-28-2014, 12:51 AM
Could be the fuel pump, but also a problem with the carb, clogged fuel filter, bad gas, etc.. Can't tell without testing, unless you like to change parts for no good reason.
Old 02-07-2015, 09:47 AM
IROC87's Avatar
Turn on the car and check if you can hear the pump running in the tank. We just replaced ours.
polinder_88
08-10-2014 12:47 AM
c4maro
05-17-2011 07:42 AM
86CamaroChris
03-15-2008 06:26 PM
YFM3501999
11-16-2005 11:37 PM
Quick Reply: 1986 z28 not starting
