Won't start, turning over slow......HELP!!!!!!
Old 02-15-2015, 02:55 PM
IROC87's Avatar
Default Won't start, turning over slow......HELP!!!!!!
87 IROC 305 TPI, turns over slow, won't start. Just bought a new battery yesterday and car acts like the battery is low. Checked it and it is at full charge. Car has not ran in about a year or so just sitting. Any help with what I need to check would be great. Thanks!
Old 02-15-2015, 04:44 PM
moved your thread to the third generation general section for you, you had it in the 4th gen. could be the cylinder walls have a light coating of corrosion that is slowing things down or could be the starter is not happy from setting and is thinking about failing. corrosion can form on starters contacts and such with can weaken its performance.
Old 02-15-2015, 05:12 PM
torque_is_good's Avatar
gotta agree with craby
it's the starter
Old 02-15-2015, 06:33 PM
IROC87's Avatar
Thank you for moving my post. I am going to buy the new starter , what length battery cable do I need to get for it?
Old 02-15-2015, 11:43 PM
If your battery cable(s) aren't broken up or falling apart, you don't need to buy any.
Old 02-16-2015, 07:45 AM
and on the flip side, if the cable to the starter is bad, then that should be the first thing replaced.
Assumptions that one makes before throwing away an appliance is that the electricity is working in the home
Old 02-16-2015, 08:33 AM
IROC87's Avatar
Going to take the cables off and get a new ones today since I have the day off. Had a 88' Suburban that started up and then went dead a second later because of that starter battery cable. The cables do not look that good at the battery, old and grey. I'm betting it looks worse down at the starter. Cleaned up the motor bay yesterday so I could see things better and work with out the spider webs, dirt and grime in my way.
Old 02-16-2015, 04:16 PM
IROC87's Avatar
I have pictures in photo bucket how do I post them here?
Old 02-16-2015, 06:00 PM
Click on your thumbnail image in photobucket to open it, click on the IMG code to copy, right click and paste here.
Old 02-16-2015, 06:38 PM
IROC87's Avatar
Got it, Thanks!
Quick Reply: Won't start, turning over slow......HELP!!!!!!
