03m45 infintia... 92 camaro rs question.....
Old Sep 11, 2011 | 12:27 AM
earthwind424's Avatar
Default 03m45 infintia... 92 camaro rs question.....
i have a 03 infinti m45 that i totaled out in a crash, but the engine still is in tack. i also have a 92 chevy camaro rs that runs great. How conceivable would it be to switch out my 03 infinti m45 engine with my chevey camaro engine?
Old Sep 11, 2011 | 01:59 AM
BasicConcepts's Avatar
Technical User
it would take ALOT of work time and money also alot of custom fab work if you have the skills time and money id say do it up altho id rather not see an infinti engine in a chevy but thats my opinion
Old Sep 11, 2011 | 10:49 AM
yea i fill you but that would be a killer fast car wouldnt you say.... 360hs v8 4.6l would be nuts...
Old Sep 11, 2011 | 10:50 AM
Old Sep 11, 2011 | 11:19 AM
and curious wat would be the most expensive part of this... i'm assuming a new trans....?
Old Sep 11, 2011 | 09:39 PM
That depends on you. Can you make steel parts? Weld? Machine shop? For a fabricator this would be fairly easy swap but most guys Cant make their own motor mounts to make up their own wiring harness it could cost you thousands in custom work. You really need to be good at EFI or do a ton of research on the infinti system. Your going to need to know what almost every wire does.
CaseyW
Dec 29, 2014 10:29 AM
alexanderr
Jan 21, 2010 07:06 PM
19camaro78
Apr 22, 2008 09:57 PM
skillz
VS
12
Mar 20, 2008 02:57 AM
