Not running right
Old 07-21-2015, 02:32 PM
roadstarjr's Avatar
Default Not running right
I have a 355 in my Camaro had some rocker arm noise , checked and one of my pined studs broke so I put in a screw in stud and it starts up fine idles good but when I get down on it act like its missing or a back fire not sure ?
Old 07-21-2015, 03:50 PM
1) Valve stem could have bent.
2) Push rod could have bent.
3) Neither, but you could have your valve lash mis-adjusted.
The stem may have pushed out for a reason, if something is binding up for instance.
You also could have valve springs that are too stiff for the press in studs to tolerate, and this one might not be the only one to pop.
Old 07-21-2015, 05:25 PM
roadstarjr's Avatar
I have about 4000 miles on motor and this is the first thing to be bad
chevyguyjay
05-13-2010 09:33 PM
Foxracing254
10-01-2009 11:32 PM
orlando_trudeau@yahoo.com
06-16-2009 12:35 PM
jake z28
12-01-2008 05:36 PM
1badroc
01-24-2005 02:55 PM
Quick Reply: Not running right
