New engine running bad
Old 06-11-2015, 08:46 PM
Kenhcook2007's Avatar
Ok so I took old carb off today again this time looked in manifold saw gas oil mix sitting in manifold why not sure maybe becouse I only had one Valve cover breathing so i added abother breather cap to the pass side put a new edelbrock thunder series 650 electric choke carb on and presto runs great again thinking the old carb was not functioning correctly
Old 06-11-2015, 09:54 PM
Be sure to check the plug wires also! I've had an engine start missing, and found a wire that had slipped loose on the distributor. The plug will foul from not firing, and make you think that's the problem, when in fact it's the result of a problem.
I've used my timing light also to assure each wire is firing at the plug. Simply clip it on, and see it flash with each firing. If it doesn't flash, there's a problem at that plug or the wire.
Old 06-11-2015, 11:13 PM
https://camaroforums.com/forum/attac...1&d=1434081492
This is the camaro finally get to drive again
Attached Thumbnails New engine running bad-screenshot_2015-05-17-20-11-43.png
Old 06-12-2015, 09:15 AM
Nice. Good to hear you got it running well, your old carb was the main suspect.
Old 06-12-2015, 10:38 PM
Ok I'm back so I took the car out brakes are from bad master cylinder got that figured out but the new carb makes the car run one all cylinders much better but could use some fine tuning so I hooked up a vac gauge to new carb and went to set air fuel mix screws and found out that that I can screw them all the way in and car won't die it might idel down a little this is on both also I can remove them completely and car still will run now keep in mind my idel is set at 1000rpm max vacum is at around 9-11 psi I can't pin point a good setting so I set them at 1 and 3/4 out. Also I completely eliminated the pvc to carb and put breather caps on both valve covers. Plugs still foul but I was running car tryn to set carb better with no luck so driving on freeway at 60 mph rpms were almost 4 grand due to the 411 gears at 60-70 it had a slight stumble .. now at idel the cars cam doesn't sound as crisp and clean as it used to so it's not lean becouse I couldn't smell gas or get that burning eye thing going on lol .. why is the carb not cutting off the engine when screws are all the way in .. still confused .. now the only thing I can think of is on the old carb I changed the metering rods richer but that was a 600 cfm the new carb is a 650 thunder so if I install the same metering rods from other carb would this possibly work .
Old 06-13-2015, 09:38 AM
First start by putting the PVC system back on. Your engine will breathe better, and last longer. Then set your idle down as low as it will idle and keep running. Then try setting the idle/air mixture with the lower idle speed. Having the idle too high is going to make it tough to set with a vacuum gauge.
Also check to ensure the new carb has a good gasket seal. If there's a vacuum leak you'll never get any response from the carb adjustments.
Old 06-13-2015, 09:53 AM
When the pvc is hooked up it sucks I believe to much oil from valve cover tho . Also thinking of changing metering rods and springs as well
Old 06-13-2015, 12:28 PM
You've got some other issue if the PCV is sucking oil from the valve cover. Need to install a baffle below it, or figure out why it's pulling oil out of the valve cover. PCV valves work, and help reduce crankcase pressures. They are one of the few improvements on modern cars that actually help make HP, and decrease crankcase pressures. Your breathers will be puking oil mist all over your engine without the PCV valve.
Old 06-16-2015, 05:20 PM
95 camaro 406's Avatar
wow that's a nice car hot ,it was making me think I need to check an see if I got one on mine,very inexspencive ,makes sence to ,?how do you like the new carb I like it ,people are surprised when I tell them 650 ,don't need anything bigger yet I love it ,hope you work that out soon ,while I check mine for pcv valve ,if not then work one in the hose
  #20
Old 06-16-2015, 05:51 PM
So The Parts Store Is Giving Me A New 650cfm Thunder Series Carb Since I Couldn't Get The Other One To Work hooked up pvc again seems to run ok I'm Going To Reset My Timming And New Carb At The Same Time It Seems To Run Decent But It Still Isn't quite right yet idles at 1000. in gear 8 hundred rpms. has a slight miss at hire rpms. I want to play with the metering rods and springs alittle and see if thst changes anything plugs still foul out but I'm sure it's due to the thumper cam and putting around .
Quick Reply: New engine running bad
