Timing Cover replacment?
Old 06-23-2010, 11:27 PM
lynchingacers's Avatar
Default Timing Cover replacment?
i got the cover leaking like crazy and i am having problems finding a replacment
iam trying to find a new one because i am thinking i might have bent the thing trying to pull it off the engine without realizing the were bolts that come up through the bottom of the oil pan
Old 09-14-2010, 04:53 PM
1976camaro's Avatar
give me the information on ur car ill find you a cover forit i need the year the engine model make all that
Old 09-20-2010, 10:19 AM
80ZJoe's Avatar
July 2010 ROTM
^^ go away
Old 09-22-2010, 11:41 PM
Question
Originally Posted by 80ZJoe
^^ go away
What's that mean Joe?
Old 09-22-2010, 11:43 PM
I'd just take the old one down to your local parts house and get a new chrome one. They're really cheap and they can match it to your old one. Be sure to pull your pan when changing the timing cover! You'll just bend up the new one trying to get the pan seal lower part in place.
Old 09-23-2010, 05:16 PM
80ZJoe's Avatar
July 2010 ROTM
Lol, there was a post there that was deleted, it was some sort of spam. Makes me look like an a$$ now lol.
Old 09-23-2010, 05:19 PM
Looks like they went away Joe! I figured there was something missing there, as it's not like you to be mean spirited.
Old 09-24-2010, 03:27 AM
i think i figured out what i did wron now... didint pull the oil pan and ended up spitting the front rail out gonna finish reinstalling it tomorrow iam kina annoyed that the water pump housing makes it aggravating to get in there...
Old 10-04-2010, 06:56 PM
Aggravating? It's impossible to change without removing the waterpump! I hope you're not rying to take it off with the water pump in place!!??
Old 10-05-2010, 02:05 PM
well crazy enough i got it to finally go back on and didn't have to remove the pan or water pump
used one minute gasket on the timing cover side on both the pan rail and paper section
i cut the small rubber tabs on the oil pan rail off added a dab of sealant to the corner
leaned the top in and kina Slid the bottom into place with a small piece of aluminum and some Very careful soft vice grip work just enough to kina push the cover flat to the block and installed the screws from underneath
then just put the bolts back on the front
Quick Reply: Timing Cover replacment?
