bogs out when in drive! need help asap!!
Old 05-07-2016, 03:03 PM
Evan383's Avatar
Default bogs out when in drive! need help asap!!
hello, I swapped a 327 into my 77 Camaro this weekend and everything went pretty smoothly until I tried to put the car into drive. The car runs and idles fine in neutral and park but when I shift it into drive, or reverse, it bogs my engine out and I'm not sure what it is. The only thing that I did with the transmission was when I pulled it off my old sbc the th350 torque converter came out if the transmission because i forgot to disconnect it, but I did put it back on and it bolted up to my block just fine. so do you think I didn't seat it all the way? or do you think its something else? thanks
Old 05-08-2016, 09:40 PM
Evan383's Avatar
nevermind got It figured out
Old 05-09-2016, 12:45 PM
Everett#2390's Avatar
Problem was ________?
Old 05-18-2016, 08:48 AM
Evan383's Avatar
timing and a misfire. the big camshaft doesn't help either, so all that was enough to bog her out, once the new spark plug was installed after removing the faulty one, and I got a timing light, she was good to go!
Evan383
70-81 V8 Tech
04-20-2016 01:01 PM
Viperlohr
10-14-2011 02:56 PM
kinder62
09-24-2009 07:12 PM
streetsk8er447
08-03-2006 07:16 PM
Quick Reply: bogs out when in drive! need help asap!!
