78 z28 clutch pedals
Old 04-06-2015, 07:31 PM
dey59's Avatar
Default 78 z28 clutch pedals
hello all 1st time here I have a 78 z28 that i'm putting a 4spd in. i found the pedals in npd my question is is my bracket set up for the dual pedals or will I need a new or different bracket to hold the new pedals. thanks for the help
Old 04-07-2015, 09:30 AM
Best bet would be to get the complete kit, since you'll need both pedals, Z bar, and all the linkage anyway. Plenty of new kits, or used assemblies on Ebay, with BIN prices around $225, and free shipping. Here's a really complete kit for $230
Camaro 73 81 Clutch Linkage 19pc Kit w Pedal Assembly in Stock Bellcrank | eBay
Old 04-07-2015, 10:11 AM
Clutch pedal mounts on the outside of your existing pedal support bracket, not in between the rails.
You should be able to see an extra tab sticking out to the left where you will attach the clutch pedal arm rubber bumper.
Old 06-22-2015, 03:02 PM
czizza's Avatar
I used the kit for my conversion and it was the better path ... especially since I am using the Z-Bar
cywelchjr
05-26-2012 10:49 PM
350
03-18-2010 11:02 AM
bluegreenta
12-21-2008 09:24 PM
Pro_built7
04-10-2007 02:07 AM
Quick Reply: 78 z28 clutch pedals
