1979 clutch question
Old 04-22-2014, 06:36 PM
79CamaroWA's Avatar
Default 1979 clutch question
Hello Everyone,
I recently moved my 79 camaro for the first time in 12 years, under its own power. and when I released the clutch peddle to engage the clutch the car jerked forward and kind of shuttered, at that point I disengaged the clutch and turned the car off. I was wondering if I should do anything to the car before I try to drive it on the streets, or is the clutch just dirty and I need to drive it? Any advice would be great. The previous owner said the clutch was fairly new before he parked it. The car sat in tall grass and the rain for most of the 12 years. Thanks for the help.
Old 04-22-2014, 08:40 PM
Yeah, that doesn't surprise me at all. Just like a bare steel brake rotor that rusts up from sitting, so can the clutch flywheel. Take the car out for a drive, and wear off that rust/corrosion.
Old 04-23-2014, 10:07 AM
I agree. If you want it to stop you need to "ride" the clutch and slip it a little until the rusty surface works off. You'll notice as you use it that it gets less "grabby" after each use.
Old 04-23-2014, 01:02 PM
79CamaroWA's Avatar
I had a feeling that this was the case. Thanks for the advice, I will take it out this weekend and do some burn outs to help clean it up.
Old 04-24-2014, 09:58 AM
Burnouts probably wont clean it up as quickly as slipping the clutch a little. Back when cars had good bumpers we would "burn in" a new clutch if it was grabbing. We put the front bumper against a tree or post and gradually let the clutch out until we felt it grab. Then hold it there and increase the rpm for a few seconds to slip the clutch and burn it in.
Old 04-24-2014, 01:49 PM
79CamaroWA's Avatar
Great advice, thank you. I will try that this weekend, then I will go have fun.
peacher1957
01-12-2015 09:52 AM
roy224
09-03-2012 09:35 AM
A-ron
05-15-2010 05:23 PM
gmman200
03-01-2009 07:40 AM
Quick Reply: 1979 clutch question
