1974 Camaro 4 speed trans?
any saginaw type three or muncie car 2wd and shifter will fit in the car if you need a new shifter this one will work only if you include your original shifter arm for the console if you dont have a console then only minor trimming for reverse to go far enough
http://www.summitracing.com/parts/sum-700000/overview/
as for transmission codes
https://www.nastyz28.com/2gcog/trans.html
has areally good breakdownof what came in the car the only real diference between them has to do with shifter bolt locations ie. a 65 impala muncie/saginaw has a strap style shifter (bigger) where as the camaros wer bolted directly to the case (slimmer)
fire0501
08-14-2015 10:54 AM
R3
North East
11-02-2010 03:54 PM
