1978 Camaro Replacement Seat Belts (Need Some Help)
Old 09-15-2016, 04:48 PM
BYoung1791's Avatar
Default 1978 Camaro Replacement Seat Belts (Need Some Help)
Hello Everyone,
This is my first time on the forum and I am looking for some help.
I just purchased a 1978 Z28 Camaro and need to replace the front drive and passenger side seat belts. I have looked around and found a few "era correct" options, but they are around $300 for the pair. Is there a cheaper option available to your knowledge? Is it possible to use newer seat belts that might be cheaper?
Your thoughts and options would be very apprecaited.
Thanks!
Old 09-19-2016, 12:21 PM
Pat Thomas's Avatar
Maybe you can find some used ones in good shape on Ebay. There are also several internet dealers that specialize in Camaro parts. Even buying aftermarket seatbelts probably won't be cheap.
Old 09-20-2016, 11:02 AM
Zspoiler's Avatar
Check the wrecking yards as well,and not just Camaros,Check the Firebirds and Novas as well.
Old 10-05-2016, 02:07 PM
Those seatbelts could be used in any gm car. Phone the auto wreckers and ask what their interchange shows as compatible models to interchange parts with.
Old 10-19-2016, 09:55 AM
quarkdude's Avatar
Default Possible replacement seat belt 1978 Camaro
I found this replacement seat belt. It's like $35.00 or so. Might work for you BYoung1791. Camaro Accessory Seat Belt, 1970-1992
Blackgloves
01-31-2013 08:57 AM
mikes77camaro
09-28-2008 09:51 PM
Ozzy
09-18-2007 09:14 PM
Quick Reply: 1978 Camaro Replacement Seat Belts (Need Some Help)
