True 1980 Z28?
Old 09-24-2016, 01:23 PM
ISCamaro's Avatar
No I don't have the build sheet.
Where exactly under the drivers seat?
Old 09-27-2016, 04:10 PM
Pat Thomas's Avatar
It's usually in the back of the backseat. You take out the back buckets by pushing them in enough for the mount to come loose, and there will be a bolt on each side of the lower backrest. Take the bolts all the way out, pull the bottom toward you just a little while also lifting upward. If the seats have never been out, it will take some work and seem like you're tearing something up, but it will be ok. The build sheet should be there if it's how I describe. If the seat back just pops out when you lift it, you're probably out of luck. But look in the springs anyway.
Old 09-27-2016, 05:16 PM
You might get lucky with a build sheet, you might not. There was no set rule for the build sheet to stay with the car once it was completed. The line workers at the end needed to get rid of the sheet, so they either stuffed it inside the car, or threw it in the trash.
Old 04-14-2021, 12:36 AM
Kitty Murray's Avatar
Default New to this so I hope I have this right.
Hello, I'm new to this - so bear with me please. I have a 1980 Camaro and kind of know what I have but need some guidance. I'm not a fool to cars. If someone can take the time out to tell me what I have for sure please.
Old 04-15-2021, 12:35 AM
Zspoiler's Avatar
You could have your insurance company look it up for you .I have a 1981 El Camino SS and mine confirmed it.And another place to look is on top of the gas tank,
Blazey
01-25-2012 10:41 AM
rcknrolfender79
10-08-2009 09:53 PM
rcknrolfender79
10-08-2009 09:15 PM
rcknrolfender79
10-08-2009 08:05 PM
rcknrolfender79
10-08-2009 08:03 PM
Quick Reply: True 1980 Z28?
