Converting my heater core hoses
Old 05-27-2016, 01:20 AM
rockgod76's Avatar
Default Converting my heater core hoses
Hey guys, in my prettying up attempts and research, I've seen some early GMs replace their rubber heater core hose with Stainless braided and AN fittings. So I went and bought myself some stainless braided hoses, -10 AN and -12 AN for the heater core and some matching fittings for the manifold and water pump.
My questions (finally, I know):
1. Are these the correct AN sizes for the heater core hoses?
2. Is there a pretty way (and how) to connect AN fittings to the Heater core stub-outs?
I have tried pushing the bare end of the braided lines onto the heater core stub and have had nothing to show but sore bleeding fingers from all the pokey braids. Ow.
Any help would be appreciated!
Old 05-27-2016, 06:28 PM
12 is a little more than 1/2 inch inside hose diamiter. did you measure the hose bibbs on the core. i thought the older camaro had 3/4 in
Old 05-27-2016, 08:41 PM
-AN is a 1/16" scale. -10 AN = 10/16 (5/8"). -12 AN = 12/16 (3/4").
Old 05-28-2016, 03:19 PM
ok, then yes they do make clamps that look like connectors for the hose. get your heat gun out (or the wife's hair dyer) and heat the hose up, can also use a hot pan of water and dip the end in, should slide right on
ztwentyate
09-12-2015 02:08 PM
sl1foru
01-16-2008 02:16 PM
dhighway
01-12-2008 07:28 PM
kyleb
12-15-2007 11:59 PM
camarohelp
12-29-2006 08:10 PM
Quick Reply: Converting my heater core hoses
