Rad overflow bottle
Old 11-12-2012, 09:18 PM
Tomg303's Avatar
Default Rad overflow bottle
I need an overflow bottle. What can I pull one off of. My access to scrap camaros is little to none.
Old 11-12-2012, 11:46 PM
80R/S's Avatar
You can mod any overflow bottle to fit I would think
Old 11-13-2012, 09:52 AM
The choices are endless! I built this one (bolted to the radiator support)from an old inert gas bottle I found in a scrap bin:
Old 11-13-2012, 10:55 AM
Tomg303's Avatar
That looks way good. Does it have to be air tight or anything? Hold a certain amount? I might have to steal your idea a little.
Old 11-13-2012, 08:35 PM
No they don't have to be air tight. They should hold a pint to a quart. My bottle is about 3/4 qt. and it never gets much in it. The hose needs to go into the bottle to near the bottom, so it will syphon coolant back as the radiator cools. Mine is just stuffed into the top and cut to be about 1" off the bottom. The strap to mount it is called a "minerallac strap" and they can be purchased at Home Depot, or any electrical supply house. They are used to hold electrical conduit, and come in sizes from 1/2" to 4". I used a 2" for mine.
adam68
02-23-2012 10:38 PM
Ron R
10-14-2008 12:09 PM
Camaro Man 1999
15
02-06-2008 12:46 AM
jkkrs310
01-11-2008 11:11 PM
Quick Reply: Rad overflow bottle
