700R4 lockup
Old Mar 1, 2012 | 08:34 AM
adam68's Avatar
Default 700R4 lockup
It appears that my 700R4 locks up as soon as it goes into 4th as I don't see a reduction in RPM. When in 4th and I slowly speed up, it does not have that RPM bump, which I assume verifies that its locked.
Is this a problem and/or ways to change it?
Thanks
Old Mar 1, 2012 | 09:23 AM
what year 700r4? have you adjusted the tv cable?
Old Mar 1, 2012 | 11:03 AM
It's also quite possible that the t.c. isn't locking up, which can be why you don't see any rpm fluctuations.
Since this trans is a retro-fit, how was the lockup feature wired, if at all?
v8xj
Oct 9, 2013 10:17 AM
microkid
Nov 28, 2010 05:37 PM
doww301
Apr 19, 2010 03:15 PM
thunder427
Dec 19, 2008 08:30 PM
The_Shadow
Nov 14, 2005 01:13 AM
