Wandering Steering
Old 03-03-2016, 10:09 AM
The tie rod end is tapered, so is the hole it goes into. In order to get the nut started, it already has to be in the hole a fair amount. If you cranked the nut down to torque specs, there's no way it can't be seated correctly. And if all you did was pop it off and pop it back on, alignment wouldn't be affected.
Old 03-03-2016, 03:24 PM
John 69 Camaro's Avatar
The tie-rod checked out ok todday and tomorrow I'll be installating a new set of the NAPA 5804 shocks and rechech the ride height. I am also scheduled for an alignment next Friday.
A question comes to mind. Does anyone think the cause of the wandering steering could be the Power Steering Box? Perhaps I screwed up something when I replaced the pitman arm.
As far as tightening the sway bar I supporrted the weight of the vehicle with floor jacks under each lower control arm.
Old 03-11-2016, 08:28 PM
I wanted to provide an update. I replaced the KYB Monosocks with new Monroe Twin Tubes and took the car for a ride. It handled better and the front end lowered. I got an alignment today and after putting the caster, camber and toe back to specs the car handled better than before I replaced the above mentioned parts.
Thanks to all for your feedback.
Old 03-11-2016, 11:52 PM
Everett#2390's Avatar
Good deal, enjoy the drive as meant to be enjoyed.
Badrs2810
06-04-2010 01:10 PM
koniz281le
08-11-2005 10:26 PM
Tony
04-30-2005 09:55 PM
euclid
04-27-2005 05:14 AM
Quick Reply: Wandering Steering
