I need help
Old 02-13-2016, 05:23 PM
Rec. Chuck's Avatar
Default I need help
I've used the search option but just didn't find what I need.
I bought a 67 camaro front subframe to put under my 55 buick with 69 camaro disc brake parts. That came in a bucket in pieces. I cannot figure out how this stuff goes back together. The way I have it now seems wrong to m . Too much gap between. The back plate and the spindle itself. Which won't allow the rotor to go all the way back on the spindle enough to put my cotter key in.
Can someone please take in depth pictures of their front disc setup so I can figure this out. Thank you.
Old 02-14-2016, 06:39 AM
flat tire's Avatar
google this, it may help
Camaro Brake Guide: How to Restore Your Chevy Camaro ...
Chevy DIY - Tech Tips Small Block Engine Performace LS1 LS2camaro-brake-guide-how-to-restore-your-chevy-ca...
If you've found a very rare car with a JL8 rear disc brake setup, retain these brakes also. .... According to the instructions in the 1967 factory Camaro Assembly Manual, the ... Always take a picture of the drumbrake springs, clips, and other components, before ... Power and Manual Front Disc Rear Drum (1967 through 1969).
CamaroEnthusiast
12-12-2013 11:05 AM
Nate3408
82-92 V8 Tech
03-30-2010 11:16 AM
superROB23
04-28-2008 06:07 PM
ALFONSO
08-20-2007 02:52 PM
Quick Reply: I need help
