Part ?
Old 08-04-2015, 10:33 PM
Kill's Avatar
Default Part ?
Hey guys, what is this? Some type of relay or?
Old 08-04-2015, 11:20 PM
GaryDoug's Avatar
If you are referring to the black device in the middle of the photo with a large wire attached, I think that is the ballast resistor. It works in conjunction with the ignition switch to provide full 12v to the coil while starting and then drop the voltage down to maybe about 8v while running. You may or may not need it, depending on the coil type and distributor type.
Old 08-05-2015, 05:17 AM
Kill's Avatar
That makes sense. I will not need it. Appreciate it brotha
Old 08-05-2015, 08:18 AM
Everett#2390's Avatar
Circuit breaker? For power top motor?
Old 08-05-2015, 11:34 AM
Everett got it, power top circuit breaker.
For the record, our ignition systems don't have a ballast resistor, it has a resistance wire feeding the coil. Full voltage to the coil when cranking is achieved at the starter through a bypass wire on the R terminal of the solenoid.
Old 08-05-2015, 05:54 PM
Kill's Avatar
Noted. I currently have the power to the top motor wired to the power wndws accessory on my new wiring harness, which has a 30 amp fuse. Is this sufficient or do i need to bring the circuit breaker into the scheme? If so, what is the setup? Note: My new scheme will not include the old voltage reg/horn relay. Appreciate you chiming in with the correct info.
Old 08-07-2015, 06:52 AM
Kill's Avatar
Nm, got it.
Ecidemon
09-03-2012 04:16 AM
BlueKitsune
11-20-2008 03:44 PM
IROCNeeveeZ28
82-92 V8 Tech
01-20-2008 01:10 PM
evansrs
82-92 V6 Tech
10-10-2007 08:53 PM
Quick Reply: Part ?
