keeps cranking but
Old 03-29-2013, 11:01 AM
mikes68's Avatar
Default keeps cranking but
Tryed to take the 73 vet out today She kept cranking checked plenty of spark from the coil getting gas still has the original distributor maybe the points or something what do you guys think .
Old 03-29-2013, 01:05 PM
Sounds like it maybe the points or something. Even though you have spark, it may be a weak one. Also make sure your 12 volt bypass wire from the starter to coil is still working. 12 volts at the coil when cranking, 10 or less through the resistance wire when running.
Old 03-30-2013, 01:05 AM
darrellv's Avatar
Camaro69 gave you good advise already. HOW DO YOU KNOW you have spark? If your using an old spark plug, sometimes a plug will "zip and spark" but not strong. It takes more volts to jump a spark tester than it does a reg. spark plug. If you have good spark and Fuel...make sure your getting spark at right time.
Old 03-30-2013, 06:51 AM
mikes68's Avatar
I have a tester that goes between the sparkplug and the wire but yes camaro69 always has good advice very knowledgeable and I will check for the right volts next weekend ,thanks to all that help
Old 04-07-2013, 08:22 AM
mikes68's Avatar
Update just changed the the points out for hei works great
jrhyno
02-19-2013 08:22 PM
91 Droptop
07-10-2011 01:32 AM
CheVy_R0aRrR
06-02-2011 11:15 PM
skinny_pedal
10-22-2009 11:58 PM
phillyfrankie
11-02-2007 04:04 PM
Quick Reply: keeps cranking but
