AC evaporator sensor plug location help please
Old Today | 07:27 AM
Alex454's Avatar
Default AC evaporator sensor plug location help please
'94 LT1 car, has a temperature sensor for AirCon operation, which is inserted between the lamels of the evaporator unit. It has a wire with the small black box and 3-pin contact on the box. Problem is - I have a body from '97, which did not have this type of sensor anymore, but want to use one (as the PCM is still '94 and needs it). Maybe somebody could help to identify where to search for the connector to the abovementioned "box" on the sensor, where it normally connects to? I assume I should have the wiring somewhere in the "under the glove box" area, but it would help a lot, if I knew where the wire is connected (going to), to find it.
Thanks a lot in advance!
Alex
the sensor itself, whoes black box is hanging in the passenger legroom behind the glove box:
Lastsparks
May 10, 2014 07:08 PM
skinut
Dec 21, 2011 10:22 AM
SixShooterCamaro
Aug 26, 2009 08:18 AM
mikeman711
Jan 11, 2009 02:28 AM
crw2008
Jul 21, 2008 08:23 AM
