LT1/LT4 Tech 1993-1997
Water temp.
Old May 19, 2026 | 05:09 PM
32rdstr's Avatar
Default Water temp.
Went for a spin over the last several days, weather near 90 degrees. On my aftermarket gauges the temp got up to 180 degrees and no further even in stop and go traffic and no fan on (manual fan switch only). Each time I noticed a quick drop from 180 to about 175 then slowly return to 180. At first I thought there was a loose connection but everything checked out. Used a non-contact thermometer to confirm the temps were correct. Is the thermostat actually cycling to cause this fluctuation?
Old May 20, 2026 | 02:29 PM
sure sounds like it. fans won't come on till around 190-200 depending on your tune. only time my fans come on is when ac is on. at least when im paying attention. mine hangs around 170. you can check gage by ohming the temp sensor and see what temp sensor is seeing. the 4th gen gages are not too accurate
Old May 21, 2026 | 05:25 PM
32rdstr's Avatar
Thanks Craby but all my gauges are aftermarket Mooneyes and I opted for a 16" manual controlled fan. All set up for computer controlled fans but guess I'm just to old school! Seems I read somewhere that the thermostat on the LT1 cycles unlike the older Chevy models.
Old May 22, 2026 | 11:31 AM
mine sure seems to act like old school. hangs right around 180 all the time. I have stock thermostat
MikeCar
May 30, 2011 11:12 PM
Redneck97
Sep 14, 2007 12:42 PM
microkid
Jun 12, 2007 02:43 PM
350rs
Jul 10, 2006 10:39 PM
ChaoticBastard
May 6, 2006 04:01 PM
