ZL1 Discussion Discussion for ZL-1 ONLY
Added a Diablo tuner and cooled air check engine light keeps coming on bank 1&2 lean
Old Dec 19, 2014 | 06:50 PM
G Clubb's Avatar
Default Added a Diablo tuner and cooled air check engine light keeps coming on bank 1&2 lean
I have a 2013 ZL1 I added a Diablo tuner and a cooled air system, I just used the 92 octane tune only no parameter adjustments made mostly because I don't know anything about engines , the check engine light comes on when the super charger starts adding pressure . The turner only tells me that bank 1&2 is lean the mass air sensor is out of test range. Please can anyone help ,I don't know anyone to take the car and tuner to, to get the car set up properly also to let you know when I put the stock air intake with a K&N filter the light does not come on. Any help will be greatly appreciated ! Gary
Old Dec 20, 2014 | 01:41 AM
Did Diablo specify that the tuner was designed to work with your particular engine? I suggest you take the thing off before the engine is damaged. You really do not want a supercharged engine to run lean.
Old Dec 20, 2014 | 03:16 PM
G Clubb's Avatar
Thanks! I did talk to the tech at Diablo and they said it was for my car but the setup from the factory was for a stock ZL1 and I would have to make adjustments for any mods I make to the car as it came from chevy. He didn't say anything about it would damage my engine ! I took the cold air system off and put the stock air system back on with a K&N filter and the light hasn't came back on and car is running good it just doesn't look as good when you raise the hood to show the car, I think I'm just going to live with it the way it is, but Thanks for the advice .gary
golieguy3000
LS Series Tech
Mar 19, 2010 04:27 AM
libertyforall1776
Mar 13, 2010 01:39 AM
joeZ28
Jul 14, 2007 02:06 PM
dragonoz
May 27, 2007 10:17 AM
