Z28 Emblem revmoval,
Hey guys i need some help removing my Z28 emblems to replace them with the chrome style ones, what and how would be the easiest way without damaging the paint, and also what would be the best way to stick the new ones on aligned properly. thanks
RE: Z28 Emblem revmoval,
First use a heat gun, they are the same shape as a hair dryer but get a lot warmer. Warm up the one for removal and slowly start to pill it away from the paint once heated with some pliers. Keep the heat to it until it is completly removed. Remove it slowly it should peal right off if it doesn't than its not hot enough and needs more of the heat going to it. For reinstalling, measure where the old ones are prior to removal so you ensure the new ones go back into its place. Also once old decals have been removed ensure that the area is completly cleaned so the new ones will stick. I hope this helps so good luck.
