Removing Ground Effects
I've removed all of the bolts and screws I could find from the drivers side ground effect/rocker panel, but it's still stuck on the top side over the quarter panel..Is there a trick to popping them off? Do I need to remove the moldings along the sides of the back seat to access screws?
There isn't an online service or body manual anywhere, is there? Any help would be greatly appreciated! |
RE: Removing Ground Effects
Maybe this might help someone in the same boat I'm in..
You have to take the door panels off and reach down in the door to get at the nuts that hold the door pieces on. There is also a nut at each end of teh door. The rear quarters have to be accessed through the trunk well area. Down by the spare tire, the glove compartment side and down in the sail panels. |
| All times are GMT -5. The time now is 05:09 AM. |
