Wheels, Tires and other Exterior Talk about your rims, body kits, and other exterior mods here.
Removing Ground Effects
Old Aug 19, 2007 | 10:04 PM
elcobra44's Avatar
Default Removing Ground Effects
I've removed all of the bolts and screws I could find from the drivers side ground effect/rocker panel, but it's still stuck on the top side over the quarter panel..Is there a trick to popping them off? Do I need to remove the moldings along the sides of the back seat to access screws?
There isn't an online service or body manual anywhere, is there?
Any help would be greatly appreciated!
Old Aug 20, 2007 | 11:00 AM
elcobra44's Avatar
Default RE: Removing Ground Effects
Maybe this might help someone in the same boat I'm in..
You have to take the door panels off and reach down in the door to get at the nuts that hold the door pieces on. There is also a nut at each end of teh door. The rear quarters have to be accessed through the trunk well area. Down by the spare tire, the glove compartment side and down in the sail panels.
Rockaholic5001
Feb 2, 2012 01:12 PM
91rscam
Jan 29, 2008 11:48 PM
serendippity
Jan 28, 2008 08:14 PM
2fast4u
Sep 20, 2006 12:05 AM
American Muscle 100
Sep 18, 2006 05:54 AM
