Wheels, Tires and other Exterior Talk about your rims, body kits, and other exterior mods here.
maximum tire width
Old Oct 17, 2007 | 10:11 PM
CamaroKid16's Avatar
Default maximum tire width
What's the widest tire i could fit on the two rear 16 in. salad shooter rims. 275's or would 265's be better. Or any other size.
Old Oct 18, 2007 | 12:46 PM
bluovlh8er's Avatar
Default RE: maximum tire width
im not gunna go into this but why do you need extra traction on a 3.4 v6? not tring to be a ****. but were you just looking for looks or do you acctually spin em? or one.
Old Oct 18, 2007 | 04:47 PM
well, mostly for looks. But thanks for no help! And mine does spin both sometimes and sometimes just one, it's wierd.
Old Nov 10, 2007 | 08:54 PM
ok, so now i found some 265/50/16's... will those fit on the 16x8 rim? just for the rear
Old Nov 19, 2007 | 12:06 AM
JordonZ28's Avatar
I ran 255's on an 8inch rim on my old mustang.....fit just fine. I'd say an 8 inch rim could take a 265, but I wouldn't go any wider than that.
Old May 3, 2008 | 08:24 AM
mxz's Avatar
mxz
255 is the maximum recommended on an 8" rim according to the BFGoodrich website.
Old May 3, 2008 | 12:02 PM
blackz87's Avatar
ORIGINAL: CamaroKid16
The larger the tirewidth is not always the best. Unless you want a part time job rolling fresh asphalt. Also those extra wide tires require a lot more torque to get going whichmeans less gas mieage for that V6.
Your confusion about spinning the tires, for one you DO NOT have a limited slip rear (RPO G80) that is why it acts that way. It is anopen rear which almost all V6 cars have..
Old May 5, 2008 | 06:39 PM
gotcha, well i've got some 295's on some c5 rims but i need wheel spacers, i got some 12mm... 1/2", will those work. When i had them up there, it was close, but i'm not sure if 1/2" will be good enough, should i get 3/4"?
AmericanMuscle1989
May 10, 2013 05:17 PM
Imperium
Feb 27, 2008 06:35 PM
chevycamaro94
Jun 24, 2007 05:35 PM
PrinceCharmmin
Sep 3, 2005 10:02 PM
freshmanit
Aug 11, 2005 01:34 AM
