Wheels, Tires and other Exterior Talk about your rims, body kits, and other exterior mods here.
How to measure wheel offset
Old May 23, 2007 | 06:44 PM
Old Oct 18, 2009 | 01:46 PM
gabe74gt's Avatar
Wheel offset is the difference between the center of the wheel and the mounting surface. Positive offset is when the mounting surface is closer to the outside of the wheel; negative offset is when the mounting surface is closer to the inside of the wheel. Negative offset will push the wheel outwards.
Old Apr 8, 2010 | 04:19 AM
tam85's Avatar
wheel offset measurement is important because an improper offset could lead to contact between the wheels and will affect the chevy performance parts of your car. calculate the wheel backspace to determine whether it is positive or negative offset. positive offset if the center line is less than your backspace and negative offset if the center line is greater than your backspace.
Old May 5, 2010 | 11:46 AM
blue_thunder01's Avatar
the thing i hate most about cars is buying wheels
Fterr99ss
LS Series Tech
May 25, 2011 01:57 PM
WesMad94
Jan 10, 2010 06:53 AM
nomonix
82-92 V6 Tech
Apr 28, 2009 10:35 PM
350rs
Nov 4, 2007 10:42 AM
psycledad
Oct 16, 2006 12:53 PM
