Wheels, Tires and other Exterior Talk about your rims, body kits, and other exterior mods here.
Fender/Quarterpanel Rust
Old 04-28-2007 | 05:03 AM
jdubs1813's Avatar
Default Fender/Quarterpanel Rust
I'm starting to notice a very slight amount of bubbling and rusting around my wheelwells. Nothing noticable unless you look underneath. I want to get rid of rust... clean it up and stop it from continuing. What's best to use here? I need something that is easy to manage so it doesn't get all over the paint since it is so close to being noticable. I'm thinking about using some fiberglass Bondo to cover it up after I take care of the rusting. What's best to do?
Old 04-28-2007 | 11:45 AM
Blade's Avatar
June 2007 ROTM
Default RE: Fender/Quarterpanel Rust
if u have rust then the area is gonna have to be cut out and patched.
Old 04-28-2007 | 03:16 PM
74454bb's Avatar
May 2007 ROTM
It may just be surface rust , but in that case still the whole qrt's will have to be sanded down to make sure a the rust is gone. If you dont plan to repaint it your self, it might be worth it to have a body shop fix it for you. If your gonna do it your self there's an all metal body filler. check with eastwood for some things. http://www.eastwoodco.com/shopping/p...roductID=10857
LessThanDrew
05-02-2009 08:12 PM
snake10556
01-14-2008 07:48 PM
mow_pro
05-08-2007 06:47 AM
Slayer
10-23-2006 03:49 AM
Quick Reply: Fender/Quarterpanel Rust
