RSX vs Z28
#31
RE: RSX vs Z28
http://findarticles.com/p/articles/m...82/ai_87105898
article states they replaced everything at 275, but stock cranks can handle about 600* not 800.
#33
RE: RSX vs Z28
a olt on 2.4 > stage 3 2.0. but 2.0 is capable of much more due to the thick cylender walls.
but ideally, the 2.2 is the best block... they just decided to give the 2.2s the gimp computers.
but GM races the 2.2s
#34
#35
RE: RSX vs Z28
yenko only the 2.2 is really built for boost and none of them are built for spray. sure there are guys running it and gettin away with it but thats on a damn good tune. you run a 25 shot through one of those untuned and its gonna run lean and melt everything in sight.
#39
RE: RSX vs Z28
I dont know about the 150 shot. If they are runing it its not near stock and must have some type of supporting mods. In fact there was a guy runing 75 wet on a 2.2 he was runing mid 14s with a few other mods. He had a back fire in the plastic intake manifold and well you know what happend. [>:]
#40
RE: RSX vs Z28
yes. i will agree there. they are running ZZP/LSJ header and downpipes, Catback, Cold Air intake, throttle body, and the main mod, is a ALLUMINUM intake manifold off of a saab. they bolt right up. that right there will let you run a 125-150shot. 150 is pushing the clutch.. but only the clutch. that would also give you a high 13 - low 14. also, obviously you'd want colder plugs too. a 150 is also prolly the limit for the pistons and rods. but the crank will handle it. easily. the next step after the 150 shot would be a performance head.
