Got spanked by a 3000GT VR4
#442
RE: Got spanked by a 3000GT VR4
there was something about your car that never looked right to me.. and i just figured it out! your tires are to dull! makes the black on black look bad! shine your tires up! lol[8D] i know i know.. that **** sprays all over the car.. but it'll make it look so much better.
#443
ORIGINAL: 3000gtskickass
*** u specter ur just tring to cover ur own *** u racist ***** ... esteinmaier... *** ur damn neon dude neons r throw away cars u might as well put ur money into a damn honda... and the reason uve never seen a 3000 faster then 13 is because u like half the other ******bags in here DONT DO NE FUKIN RESEARCH... so *** u specter n *** u esteinmaier
Neons are throw-away cars. I won't deny that. But after you build a car, you will realize that the car you started with is just a way to get to your goals. It's light, and I can get as much power as I can afford under the hood of it. Goal met. Hell, if I threw an LS1 into my car (if it were even possible to make it fit without moving the firewall) it wouldn't be any faster just because of the weight.
I put my money into my performance build. If that were in a Honda, a Camaro, or a Neon, it's still my performance build, regardless of the unibody it's pulling down the track. Take the powertrain out of a 3KGT and a Neon, and tell me which is faster. That's right, the neon, cuz you gotta push it down the track and it weighs less.
So my point is this: Lick me, R-Tard. I'm much faster than you, even in my "throw-away car".
#446
ORIGINAL: ninetysixyenko
#449
hes lying through his teeth now. and he just admitted that he was just the same as a stock srt4
hey motard, estein is over a full second faster than a stock srt-4, that being said, an srt4 stock is a full second faster than you easy. you came in here 20 pages ago saying "15s? no, i bet i could get a 14 out of her" meaning that you have approx ZERO track experience. then u say you will win bracket racing with ZERO track experience . u really should stop and think, u are talking to people with alot more experience in this stuff than you do, so dont boldfaced BS us.
the car u posted says stock except for the rims.
you have proven to have no track time under your belt.
you know absolutely nothing about the power capabilities of any other car we have discussed, and very little about your own car.
i really feel like u just bought the damn thing, got the minimal kick in the pants a sporty looking pig like a 3000gt can give, and thought u were invincible. get a clue man.
#450
Cool. Put some money on it. Hell, put a 150 shot on your car and see if you can compete still.
3350lbs/222hp for a base 3KGT such as yours. About 15lbs per HP.
2100lbs/375hp for my car (It will be a couple weeks though. I have some rings to file) is about 5.6 lbs per HP.
Those are also crank HP numbers VS. wheel HP numbers, so the difference is even more dramatic. My crank numbers will be closer to 430, the way your HP is measured. Better than a 5:1 ratio compared to your 15:1.
I'm not sure how you think you'll keep up with that. Let's use numbers from my last dyno, before the cam. That was 220 with a heat-soaked intercooler. That's still a 9.5:1 ratio.
How about an SRT4? 230hp, 2950 lbs. 12.8:1 ratio. Close, but you still lose unless your buddy can't drive.
The only way you would ever win a 1/4 mile race against my car is if I broke something.
1/8 mile, we already know that I run an 8.0, and you run a high 9. Top speed? I don't know. I don't have tires that go that fast. Previous setup was well over 150. The car wanted to go, and I kept picturing the all season tires blowing out, so I didn't stay on it.
