New Power Stop Performance Brake Kits Rebate at CARiD
https://images.carid.com/powerstop/p...p-promo-16.jpg https://www.carid.com/powerstop/ The factory brake rotors and pads on your Chevy Camaro are decent enough for the average daily driver, but if you strive for more, you need a total braking system upgrade. With the PowerStop brake kit, you'll get everything needed to upgrade your wearable brake parts all in one package. These braking systems replace factory rotors and pads on all four wheels of your Camaro with improved hardware that will improve the bite, improve the stopping power, and reduce brake dust. This October, you have an opportunity to save up to $60 OFF with a purchase of PowerStop Z23, Z26, and Z36 brake upgrade kits at CARiD. This offer ends on October 31, 2020. Please fill in the PDF form to get your reward: https://images.carid.com/powerstop/p...ebate-form.pdf Power Stop® - 1-Click Z23 Evolution Sport Drilled and Slotted Brake Kit with Calipers https://www.carid.com/powerstop/1-cl...-calipers.html https://images.carid.com/powerstop/b...h-calipers.jpg https://images.carid.com/powerstop/i...-upgrade-2.jpg https://images.carid.com/powerstop/i...rake-kit-6.jpg Benefits: Slots help to increase pad bite and improve air circulation Drilled Holes and Slots create an escape route for debris, dust, gases, and water Slots clean and de-glaze pad surface for optimum pad coefficient of friction Drilled rotors improve the appearance of your wheels and provide reduced rotor weight Power Stop® - 1-Click Street Warrior Z26 Drilled and Slotted Brake Kit https://www.carid.com/powerstop/1-cl...brake-kit.html https://images.carid.com/powerstop/b...-brake-kit.jpg https://images.carid.com/powerstop/b...-brake-kit.jpg https://images.carid.com/powerstop/i...rake-kit-6.jpg Benefits: Drilled holes and Slots create an escape route for debris, dust, gases, and water Slots clean and de-glaze pad surface for optimum pad coefficient of friction Drilled rotors improve the appearance of your wheels and provide reduced rotor weight Slots help to increase pad bite and improve air circulation |
