Tranny popping out of reverse
Hey all. I have a 5spd tranny. Tranny fluid was changed early last year. I just started driving it again this year and when I let the clutch out to go in reverse I hear a bang and it pops me out of reverse. I've heard it was a known issue with the t5 and it's the reverse gear that gets worn. Is there anything else I can do? It's always been hard to put in reverse since I got it, and I have to play around with the shifter to get it in reverse. I hope I don't need to replace the tranny. The forward gears seem to work great.
Well, I think I found my answer. Here's a technical service bulletin. I'm still interested in any tips or tricks anyone has.
Vehicle: All Technical Service Bulletins
M/T - Jump Out of Gear Condition
File In Section: 7 - Transmission
Bulletin No.: 67-72-03
Date: September, 1996
Subject:
Borg-Warner T5 5-Speed Manual Transmission Jumps Out of Gear in Reverse (Replace Transmission Assembly)
Models:
1993-95 Chevrolet Camaro
1993-95 Pontiac Firebird
with T5 5-Speed Manual Transmission (RPO M49)
Condition
You may receive comments concerning a "jump out of gear" condition for the reverse gear in a Borg-Warner T5 5-speed manual transmission.
Cause
Insufficient load at the reverse linkage may permit transmission to disengage from reverse.Bulletin No.: 67-72-03
Subject:
Models:
Condition
Cause
I guess the question is how long do I have? Will it go in the forward gears too or will I eventually not be able to go in reverse? I'm going to check the fluid today and maybe add an additive to the tranny.
Will a 5-speed out of a 96+ Camaro/Firebird work? Will a 5-speed out of an older V6 work (88-92)?
I'm going to take out the center console this weekend and check the shifter in case it's not seated right or a spring is broken.
And, I found a shop that will rebuild my tranny for $500.00 if I take the tranny out and put it back in.
