April ROTM Winner! 2009
This month was a great month....so close for so long, lots of votes for lots of people. I just want to thank everyone who voted. I've been a member here for a little while and just never thought it would be me one day. My car and I appreciate being part of this great community of Fbody fanatics! This was a very tough group with a bunch a great cars!
Thanks everyone for the great honor!
And as per request (evilkal) here is a list of most of my mods ... in and out:
INTERIOR
*Polished Aluminum Shifter ball
*Polished Aluminum Custom A/C and Headlight *****
*Brushed Aluminum Bezel
*Polished Aluminum Door sills
*Custom "Camaro Z28" stitched Floor mats and Hatch mat
*Brushed Aluminum overlay kit for the Door/window control panel and glove box
*Polished Aluminum Pedals and foot rest with Z28 Eched on them. (real pedals NOT covers)
*Brushed Aluminum Bowtie sticker for steering wheel
*LEDs----- Blue in the Speedo and a/c control panel as well as the lights above the door/window control switch. Hyperwhites in map lights and hatch light
EXTERIOR
*35th anniversary Stripes
*SS fiberglass hood
*RS Factory Body Kit
*Black Riveted Z06 wheels 17x9.5 all around
*Export Tailights
*SLP Grill Body match painted with Black Vinyl Bowtie
*"Berger" style semi gloss rear panel
*Carbon Fiber vinyl sail panels
*Halo headlamps
*HID headlights
*HID fog lights
*Clear Corners with Amber LED's
*Clear Rear marker lenses with Red LEDs
*Custom 3rd brake light with chrome interior, clear lense and Red LED's, and black Z28 vinyl overlay
*Drilled and Slotted rotors (yeah I count them as appearance
*Brushed Aluminum Custom Antenna
*The follow are all Poslished Stainless Steel: Z28 emblems, CAMARO letter inserts, rear Bowtie (with carbon insert), rear LS1 emblem,
Z28 chevy bowtie nose emblem (with carbon insert)
*Polished aluminum air dam
*Thunder Racing's Aluminum rear differential cover
*Meggs Polished Stainless steel Dual Dual 3.5 exhaust tips (for show only non functional of course
*Polished aluminum piston shaped caps (that cover the little air spicket that you use to fill up you tires) forgot what its called
*LED's--- rear tailights (red), reverse lights (hyper) and turn signals (hyper)
Engine Bay/Area
*The follow is all Polished Stainless Steel:
-under hood mirror kit
-Fuse box area cover
-Aftermarket Powersteering Pulley
-Power steering/ABS cover
-Screws/bolts and washer kit
-PCM cover
-Front nose Cover
-Fuel Rail emblems with CAMARO etching
-Traction Control Box Cover
-Battery Cover
-Cover for TB connection area
*Hotchkis Polished Strut tower brace
*Real Aluminized Carbon Fiber fuel rail covers
*Polished aluminum:
-Brake fluid cap
-Power steering cap
-Engine oil cap
-Radiator cap
-Radiator Resivoir Cap
-Master cylinder cover with cap
*Hand Polished to mirror or near mirror finish:
-A/C condensor
-Abs Box and tubing
-Various Brackets
-Strut shafts
-Various tubing / piping throughout area
*Aluminized Carbon fiber wrapped hood struts
*Chrome air hose filter
* !Wires delete mod
* !Windshield washer fluid resevoir delete mod
SUSPENSION
*BMR Lower control arms
*BMR Subframe connectors
*Spohn Front and rear Sway Bars
*Bilstein HD Shocks
PERFORMANCE
*Longtube Ceramic Coated Headers
*True dual Xpipe (daul 3" pipes dumped before the rear axle)
*Volant CAI
*85mm SLP MAF
*Powerbond Pulley
*NGK TR55 plugs with 8mm wiring
*37# injectors
*LS2 timing chain
*Hardened Chromoly pushrods
*F.A.S.T 90mm intake
*Nick Willams 90mm Throttle body
*PRC Stage 2.5 Ported LS6 heads with dual spring kit good to .660 lift, titanium retainers...etc etc
*Cometics Gaskets (.040)
*231/234 .644/.598 on a 112 LSA TRAK cam from Thunder Racing
*Tuning done by Patrick G (of LS1Tech and Thunder Racing fame)
*OZ700 Series Textralia Clutch w/Billet steel Flywheel and new Slave cylinder
*Pro 5.0 Short throw shifter
ok I may have missed a couple of things here but I got most of it
INTERIOR
EXTERIOR
*SS fiberglass hood
*Export Tailights
*Halo headlamps
*HID headlights
*HID fog lights
)*Brushed Aluminum Custom Antenna
)*Polished aluminum piston shaped caps (that cover the little air spicket that you use to fill up you tires) forgot what its called
Engine Bay/Area
-PCM cover
-Front nose Cover
-Battery Cover
*Polished aluminum:
-Brake fluid cap
-Power steering cap
-Engine oil cap
-Radiator cap
-A/C condensor
-Abs Box and tubing
-Various Brackets
-Strut shafts
* !Wires delete mod
SUSPENSION
*Bilstein HD Shocks
PERFORMANCE
*Volant CAI
*85mm SLP MAF
*Powerbond Pulley
*37# injectors
*LS2 timing chain
i said it in the other thread but congratulations man! was a hell of a battle there for a little bit...but then you just ran away with it. do us a favor and post pictures in here so people that didn't see that other thread know why your car won...
i actually had a dream last night that spec caught zoilus, musicman and I making fake screen names and voting for ourselves so he disqualified all of us and arrow ended up winning! i know...i'm pretty much retarded
jk
