280z, Camaro powertrain.
Old Oct 5, 2011 | 01:17 PM
I am still wondering why the induction is geared toward a high winding motor. I honestly don't think the semi stock 305 bottom end is gonna like much more than 5500 rpm. I guarantee it will puke after a few pulls to 8000.
Old Oct 5, 2011 | 01:38 PM
Be sure to drape a net below the oil pan to catch the parts!
Old Oct 6, 2011 | 09:06 AM
On the water pump issue not aligning. It might be that you have a short water pump, and from the look of your pulley setup you need the long water pump.
Old Dec 19, 2011 | 02:13 PM
bucketlist2011's Avatar
LMAO.... Yep... I am running the 71 LT-1 , and it pulls to 7000...Maybe more, but that is where I shift..6500 or so...
But it has 4 bolt. heavy duty caps, screw in studs, 2.02's, ect...
A 305 should be made to go to about 5500 or 6000...
But a small block in a Z car...woo hoo.....Shift sooner and last longer..More fun that way...
I will be setting my new MSD to 6500rpm...
Old Dec 19, 2011 | 06:27 PM
So what's going on with the car/engine swap? Have you got the water pump figured out? Any forward movement on the install? Did the guys questions about rpm's put you off and you're not here anymore?
BlackG5SPD
Feb 16, 2014 10:58 AM
z28pete
Jan 24, 2008 07:20 PM
