Twin Turbo V6
RE: Twin Turbo V6
We didnt say it COULDNT be done stang... we said its not a good idea... Point proven... did you see the chunks of **** on the ground after he did his run? Only a fool will force feed a turbo into a STOCK internal engine... thats just asking for trouble... While on this subject, why dont we just tell him to port and polish his intake and heads by hooking up a 25lb bag of fine ground sand to his intake???
RE: Twin Turbo V6
Because that is retarded. I didn't see anything on the ground. I'm not saying it's a good idea either.That guy makes turbo kits for the f-body's. I'm just showingwhat you can do if you know what you're doing.
RE: Twin Turbo V6
ORIGINAL: omarrakeen
wt if was a 3.8 ??
wt if was a 3.8 ??
RE: Twin Turbo V6
the 3.8 is a much better engine... (sorry 3.4 guys) it can handle more boost stock and the starting horse power is higher so you get more HP per pound of boost however it is still not an easy process
