turbo'd automatic
I'm thinking of turbochrging my Z28 LS1... the kit I'm looking at is around 4700.00. The reason for the turbo is because my car is an automatic. Does anyone have a turbo on their car? If I had the 6sp I'd be more inclined to go with the supercharger.
i have/had a nissan 240sx coupe 5 speed that had a t15 turbo on it the power is amazing but i had pistions cam steel crank and a home made intakemanafold but u need to get your car tuned when you turbo it also look for external waste gate turbos and u want somethink that spools super fast to make power and do not run it with out wastegate compresser surger can bust crack and when u do that it takes all the parts threw your motor not good but u will also need better head gaskets well good luck and remember boost over 35psi can internaly hert your intake
ORIGINAL: natrous
It doesn't matter whether you have a auto or manual....what is your reasoning for this???
ORIGINAL: Pipanski
ORIGINAL: natrous
Supercharger:
Pro's - Instant boost, don't have to wait for a turbo to spool up. No turbo lag. Awesome sound hahaha. No costly custom made manifolds, or funky turbo in the rear set ups.
Con's - In order to adjust boost, you have to replace a pully. Takes approx. 100hp from the crank to produce boost (from what I've heard!).
Turbo:
Pro's - Adjusting boost is simple, tons of power. Doesn't take power from the crank to produce the boost.
Con's - Turbo lag, costly manifolds or funky set up in the rear, slow spool compared to supercharger...
thats my outlook on it.. supercharger all the way!
SO IF i PUT A TURBO OR SUPERCHARGER on my camaro and it is auto it all good I thougth that it didn't work as well with an auto for these I dunno what made me think that.... Thanks nick * I mean I knew you could and all but I dunno what I was thinking* tahnks nick!~
ORIGINAL: t4nk
I agree.. This does not matter.. However there are some really good pro's to superchargers..
Supercharger:
Turbo:
ORIGINAL: Pipanski
ORIGINAL: natrous
Supercharger:
Turbo:
[/quote]
[/quote]
Only if you have an incorrectly chosed turbo setup, or use on of those *ahem* shall I be safe to say "Questionable" rear-mounted turbo kits.
We had a Turbo LS1 with a GT42 hanging off of it at the shop that was anything but laggy, and made a nice 590whp/640ft/lbs. (that might be off by +/- 10 whp & ft/lbs.---it's been a while since I had the dyno sheet in front of me) on the stock motor @ 9 psi on pump gas.
When was the last time you've driven a turbo'd car. Technology is amazing these days beacuse the waste gate stays open when there is low pressure. So when you mash down on the throttle it closes so it starts spooling a lot sooner. With a boost controller, you can have spool up as fast, if not faster than a super charger. Turbos take less horsepower to run also. Turbos are the best way to have a power adder. How many cars come stock with a super charger? Pontiac GTP, Ford F150 Lightning, Ford GT, and the Impala SS.
What comes with turbos? Evo VIII, Fox chassis mustangs had an option for a turbo, Desiels have turbo chargers and not super chargers. Drive the Diesel Cummins or the Powerstroke or GM Desiels all have turbos. Turbos are now the power adder of choice these days. You have more room for intercoolers and you can have your CO2 coolers and your nitrous on the intake by the throttle body. You can change a turbo out just as easily as 9 bolts and 6 hoses. If you get a ball bearinged turbo, it'll last you a lot longer than a supercharger. The screw impellers on the roots style blower ware out and allow blow by and leaks oil from the throttle body. (F150 lightning)
