Turbo for a 2000 3.8
A LS1 Z28 will be more drivable, more reliable and cheaper. A turbo V6 is expensive, kills MPG's and will not be as reliable. I'm not being an idiot, I'm being realistic. He's going to need to get that motor built to handle the boost. Like forged pistons, forged rods, turbo camshaft, etc. These are not cheap.
now what youll need
turbo kit - prob around 2000$
intercooler - around 500$ (unless it comes with the turbo but that one is prob junk)
upgraded fuel system - 200-500$
turbo headers - prob need to be custom maybe some where between 500-1000$
ill stop there i can smell your wallet burning
ohh dont forget the tune
not trying to side with buff here but he is right if you want a fast car you should look into trade in the 3800 and getting an LS1 unless you want to spend the money and have your car out of commission for at least a month and then have to mess with it for just about ever
also if gm made 2 diff 3800 (SC ready and NA) there really dumb lololol
Just did research and you're right. The T5 will do with a 325 lb-ft torque rating. I didn't think that it was that stout. The rear end will depend on if this guy will want to run with taller gears.
id deff say swap in a SS rear tho what good is all that power if only 1 tire spins
but ya the 3800 is a beast it was placed in the top 3 engines ever built this year and the drive train is good to as long as everything is taken care of now if the trans fluid had 150k on it and the diff fluid has never been changed and the engine oil goes for 10k every time than your sol
you should just spray thats funnnnnnnnnnnnnnnnnn
i would hope the LS1 has way more power than the 3800 plus its posi and disk
is the 00 3800 rear disk or drum idk i have drum and i HEET it
i just got done putting brakes all around on a 06 kia with rear drum i HEET drums there so ugly and such a pain the the butt to work on stupid springs
but just checked autozone.com and it says disk on the 00 3800
