ProCharger
Does anyone have a procharger that the can measure the clearance between the impeller and the Inlet? I have one tore apart with no starting point, the OEM shim allows me to press the impeller onto the body of the charger... where the gears are and gives the impeller a tolerance on the inlet I think is excessive.
