New Nitrous kit... Questions :)
Well i decided to start a little project. after i installed my Headers.
I currently bought a Nitrous Oxide System, Zex, Wet, 75-125 hp I have also bought a new Fuel Pump, Electric, In-Tank, 255 lph, Due to the Nitrous kit being made for an ls1. I have also bought a Nitrous Oxide Racer's Tuning Kit (Safety FIRST!!!) (all items were bought from Summit) I would like to know what ur guys opinion is on Nitrous. and how likely am i to mess my engine up? 95 z28 5.7 and would u recommend i replace my AC Delco spark plugs with ones that have multiple ends on them (Spitfire est.). |
u should be fine as long as u don't run the bottle empty and keep the bottle psi up and warm and your motor is some what in good shape if not rebuild motor then run nos good luck
tune tune tune. then you should be ok
Alright dearly noted. thx
In preparation for my tune up. i got high performance spark plugs/wires, coil, opti, fuel filter, fuel pump, oil filter. |
what plugs did you get? you need to go a step colder for nitrous. NKG TR7 (i believe) are the way to go.
Bosch Platinum + 4 Spark Plug 4458
Im buying these even though i just bought. brand new ACDelco plugs 1 week ago. http://static.summitracing.com/globa...bch-4418_w.jpg |
No Platinum. The Ngk tr6 or tr7 very good with nitrous, all the tuner guys I talk to say run Ngk. JMO
May i ask why? Does it matter?
because you need to make sure the plug has a colder operating range to avoid detonation. detonation+nitrous = you buying a new car
Originally Posted by SpecterGT260
(Post 368859)
