need some pony's
I have a 2.8L(i think) V-6 with a few mods.
Current mods: Dual Extended Flow Master kit New ignition starter(starts on first crank) What I want is to increase the stock 155hp to around 200 if possible. Im kinda new to the muscle car modding as I have only worked with and mostly know about turner cars and exterior work. I can take a pic of it if it helps. I will post one soon. I will be replacing the headers very soon as they are the first things on my list. Is there anything I can do to it to reach around 200? |
RE: need some pony's
your on the right track header down pipe high flow cat will give you more power and you wont fail emessions assumeing they have them were you live good cam would put you right about the 200 range
how much am I looking at for the cams, headers, and carb.
well you can usually get the cam itself pretty but if you paying for the install it will cost you headers kinda the same way as for carbs mines fuel injected so i dunno
