dry or wet shot
RE: dry or wet shot
you will want to go with a wet shot. The "wet' shot is typically preferred since the nitrous is injected with additional fuel into the engine whereas a "dry" shot injects nitrous alone. wet systems can be tuned by adjusting the fuel pressure up or down. Dry systems rely on the engine's computer alone which for example if it senses it is running too lean it will pump more fuel but most factory computers were not designed with this in mind so they have difficulty compensating for the nitrous. The wet shot is injected directly into your intake (usually same place as injectors) whereas the Dry is shot through the air intake.
RE: dry or wet shot
How big of a shot do you want to go with. You can go with a 75 shot dry nitrous safely, but anything over that I'd go wet. You can get the easier wet shot that injects both fuel and nitrous throught the intake tube too. Direct port injection is a lot more expensive and you need to machine your intake manifold a little too.
javione
02-22-2007 03:45 PM
