Kinda new guy from NY with a small problem
My intake is leaking oil and in order to run it on the strip i need that fixed, also in order to get it tuned i need if fixed how hard is it to fix the seal?
Be nice to know year and engine used.
Sorry about that its a 95 LT1 I heard there are 2 seals on the intake?
1 Attachment(s)
hay welcome to the forum. intake leaks are common with the lt1. u will need to get the intake gaskets and some high temp rvt for the ends. as u can see in the pic u need to put enough on to goop out a bit. its easier to have something to hold the manifold up away from the rvt as u are installing so as not to mess it up before dropping it down. i used some pieces of pencil trimmed down just a tad to get a tight fit in the bolt holes. u will want to measure them so u can get them out after the manifold is in.
Attachment 35225 |
