-   LT1/LT4 Tech (https://camaroforums.com/forum/lt1-lt4-tech-9/)
-   -   Z28 bogging out and back firing (https://camaroforums.com/forum/lt1-lt4-tech-9/z28-bogging-out-back-firing-65955/)
dhaby Nov 7, 2011 11:25 AM
The problem im having is that my car is bogging out at about 80 mph about 5000 rpm and is letting out a large back fire. During the series of pops it becomes unresponsive with the gas. A friend driving behind me told me that he also saw flames shoot out. I didn't see it so I'm not sure on the flames. Another friend who knows lt1's suggested it might be my ignition control module or maybe a bad opti. Any opinions or suggestions are welcome and appreciated. Thanks.
craby Nov 7, 2011 12:24 PM
scan it for trouble codes. could be a number of things including the icm or opti or just a bad connection or fouled plugs or fouled/failing 02 sensors or fuel pressure or plug wires,,,,
dhaby Nov 7, 2011 12:56 PM
I wanna do that but there are no lights on so would a code still show up if no check engine light?
craby Nov 7, 2011 01:45 PM
it could yes. i have seen the bulb for the ses light burnt out and disconnected.
dhaby Nov 7, 2011 02:12 PM
Oh okay. Well I know my check engine light works. It's been on not to long ago but went off after we gutted my cat out.
craby Nov 7, 2011 08:23 PM
if the light came on it should have a code, that is unless you unhooked the battery that would clear the codes.
torque_is_good Nov 8, 2011 02:08 PM
good grief man, what rear gear ratio do you have to be spinning 5k rpms at 80 mph?
sounds ignition-ish to me
if i were a gambling man....................optispark
greenmachine96 Nov 8, 2011 08:53 PM
did he mention if it was at WOT or just driving at 80 lol. I would think that a code would come up if he was at 5000 rpms just driving normally/ highway cruising. My first action would be have it scanned and maybe have them look at some live data from the MAF and O2's to get an idea of how the fuel/air mixture is and then if all looks good, I would guess the opti is bad. Craby knows best on these lt1's though so his advice is always good to follow.
dhaby Nov 9, 2011 08:29 AM
haha. idk if it was exactly 5k i just remember glancing at it when the popping began and it was on that end of the tach.
and greenmachine96 I'm going tomorrow to get it scanned, i'll see if they can read some live data and find out about the fuel/air ratio.
