z28 been sitting for 3 years
You can use a dent puller, but it would be better to use a stud welder and puller. That way you don't have a bunch of holes in the quarter panel that require welding up. Color matching will be the hardest part of that repair.
BTW - that is a fairly common location for a dent on the fourth gens. I have seen numerous similar dents on other cars in almost the exact same spot and about the same size.
I believe that is made out of a plastic resin. You might be able to do a repair on it with fiberglass and some bondo, as it is a small area that is damaged. Your other choice would be to locate a good piece at a wrecking yard or buy new and just replace the whole thing.
sroberts
02-04-2009 01:28 PM
