Wobbling Harmonic Balancer -- bent crank snout?
Hi guys,
A few weeks ago I noticed that my harmonic balancer/dampener was wobbling. I checked on the forums, and found that more that likely it is just the dampener itself. I have tried 3 different brand new dampeners and 2 used ones. The wobble remained.
I replaced the hub next. I put everything back together, and the wobble remains. Should I bother trying another harmonic balancer? I did notice that each balancer I tried had a different type of wobble to them --which was odd.
I think my crank snout has been bent somehow -- I don't know how it happened, but I don't see any other possibility. Is there anything else I can try? I don't have room to tear the engine out at my apartment complex... will driving around with this wobble destroy my engine right away?
does the motor vibrate? the front of the motor is internally ballanced so the front balancer does nothing except add a little counter balance weight. is it a in and out wobble or a up and down wobble?
DashingDaryl
06-06-2012 06:15 PM
