where are the grounds?
you have a ground on the block in front of the starter. one on the passenger side motor mount, one on the front of the block on the driver side by the coil, one under the belt tensioner. your also have power and ground junction boxes on the passenger side wheelwell that you could cleanup with a wire brush.
heres a couple grounds inside
