-   LT1/LT4 Tech (https://camaroforums.com/forum/lt1-lt4-tech-9/)
-   -   Where does this stuff go? (https://camaroforums.com/forum/lt1-lt4-tech-9/where-does-stuff-go-68323/)
Mikey. Feb 28, 2012 03:23 PM
Creative title, I know. I'm having a lot of trouble finding out where some of these loose odds and ends go. The previous owner obviously didn't care about the car. It's a 97 Pontiac Trans Am Lt1 with a T56
Is this hvac tee hooked up correctly? Top goes to the intake manifold, bottom goes god knows where, and the straight section goes towards the dash. If I pull the bottom line, there is suction through the tee.
http://i39.tinypic.com/ws4gee.jpg
Does anyone know what this hard line is? It goes into the harness and then idk where from there. It's not hooked up to anything.
http://i43.tinypic.com/33mq448.jpg
This one, I probably don't need a picture for, but is there supposed to be a relay in this open spot?
http://i40.tinypic.com/15drnuf.jpg
This last one, is on the driver side by the brake booster. Honestly I don't know what the little reservoir is, but there's a melted hardline floating around behind it. Anyone know what it goes to?
http://i44.tinypic.com/2n8sfv5.jpg
Thanks guys. :icon_gunhead:
x01660 Feb 28, 2012 04:14 PM
Here ya go, Mikey. :)
https://camaroforums.com/forum/lt1-l...ing-car-68314/
x01660
Catmaigne Feb 28, 2012 04:37 PM
That's the check valve for the HVAC system and everything appears to be plugged in correctly. If you don't have air through your dash vents then your check valve might be rotted and needs to be replaced. If you do, leave it alone.
That's your clutch hydraulic system reservoir and it's filled with DOT3. It normally should slide into a bracket and mount with one plastic screw.
Mikey. Feb 29, 2012 08:06 PM
If someone could post the pictures of these parts on their cars it would help a ton.
BasicConcepts Feb 29, 2012 08:13 PM
your first pic looks good i wouldnt mess with it
now the second pic... the only thing i can think of that line being would be the washer fluid. does yours work?
third pic looks good both my camaros had an open spot there
and the forth pic looks good thats exactly how the clutch res should be mounted. as for the line there im thinking evap? give it a good wiggle (not to hard dont want to break it) just to see if its really not connected to anything
ive had the engine out of my Z twice and dont remember any vac lines over on that side of the engine
Mikey. Mar 1, 2012 09:42 AM
Thank you for the reply.
My washer fluid doesn't come out when I hold the switch, I assumed the motor was bad. I will definitely look into that.
BasicConcepts Mar 1, 2012 12:01 PM
ya theres no vac lines going to the front of the car it has to be the washer
