LT1/LT4 Tech 1993-1997
Where does this stuff go?
Old Feb 28, 2012 | 03:23 PM
Mikey.'s Avatar
Default Where does this stuff go?
Creative title, I know. I'm having a lot of trouble finding out where some of these loose odds and ends go. The previous owner obviously didn't care about the car. It's a 97 Pontiac Trans Am Lt1 with a T56
Is this hvac tee hooked up correctly? Top goes to the intake manifold, bottom goes god knows where, and the straight section goes towards the dash. If I pull the bottom line, there is suction through the tee.
Does anyone know what this hard line is? It goes into the harness and then idk where from there. It's not hooked up to anything.
This one, I probably don't need a picture for, but is there supposed to be a relay in this open spot?
This last one, is on the driver side by the brake booster. Honestly I don't know what the little reservoir is, but there's a melted hardline floating around behind it. Anyone know what it goes to?
Thanks guys.
Old Feb 28, 2012 | 04:14 PM
x01660's Avatar
The Mustang Hunter
Old Feb 28, 2012 | 04:37 PM
Catmaigne's Avatar
That's the check valve for the HVAC system and everything appears to be plugged in correctly. If you don't have air through your dash vents then your check valve might be rotted and needs to be replaced. If you do, leave it alone.
That's your clutch hydraulic system reservoir and it's filled with DOT3. It normally should slide into a bracket and mount with one plastic screw.
Old Feb 29, 2012 | 08:06 PM
Mikey.'s Avatar
If someone could post the pictures of these parts on their cars it would help a ton.
Old Feb 29, 2012 | 08:13 PM
BasicConcepts's Avatar
Technical User
your first pic looks good i wouldnt mess with it
now the second pic... the only thing i can think of that line being would be the washer fluid. does yours work?
third pic looks good both my camaros had an open spot there
and the forth pic looks good thats exactly how the clutch res should be mounted. as for the line there im thinking evap? give it a good wiggle (not to hard dont want to break it) just to see if its really not connected to anything
ive had the engine out of my Z twice and dont remember any vac lines over on that side of the engine
Old Mar 1, 2012 | 09:42 AM
Mikey.'s Avatar
Thank you for the reply.
My washer fluid doesn't come out when I hold the switch, I assumed the motor was bad. I will definitely look into that.
Old Mar 1, 2012 | 12:01 PM
Technical User
ya theres no vac lines going to the front of the car it has to be the washer
Devin's camaro
Feb 22, 2011 08:50 PM
Devin's camaro
Jan 29, 2011 02:09 PM
n8_camaro_92
82-92 V6 Tech
Feb 2, 2009 11:30 PM
camaraddict
Jan 22, 2008 02:04 AM
